PCV Elimination Plug
ROYAL_6
I'm in the process of eliminating the PCV valve in my car ('87-T) and was wondering if anyone has used a rubber plug to block off the PCV hole in the intake.
I've used the search feature on here, and have found that many have drilled and tapped the intake or have simply plugged/capped the PCV valve or plugged the the PCV hose.
Before I remove the intake to drill and tap it, I was wondering if anyone has used a rubber plug to block off the intake hole. If so, what rubber plug or cap did you use?
Chuck-Do you know which part number on this PCV device plug will be needed for deletion ??
I've not measured the hole.
I had welded mine closed when I built the stage engine.
Maybe someone with a manifold off can measure it.
Anyone with a Champion lor stock Intake --can you measure the diamter of the PCV hole??
It seems more folks have added catch cans to the PCV system than anything else, although some have added an extra breather in that hole as well as the valve covers.
This breather pops right in the PCV grommet.
The above link does work.
Dont block it, rather tap the hole and screw a fitting there with a hose.
I think that the hole is 3/4 but dont quite remember.
The size of the GM OEM grommet is .940”.
I suspect the hole in the intake is slightly smaller.
That should get you close for an expanding plug.
If you decide to use a fitting in the grommet, it’s right at .500”.
I did come across one old post that mentioned they used a small filter as the one you suggested. I guess it helps and its better than plugging the hole. Thanks for the link.
Curious to why your removing PCV valve?
it's in a really bad spot.
I just had an oil report come back with really high copper. Tore the engine down and the mains were trashed from trash.
When I pulled in the intake, there was a splotch of grit on the valley pan right below the PCV valve. The grommet had gotten hard and wasn't sealing and the valley is a low point so garbage gets in there and drains into the engine. Seems that spot is the most likely place for trash to get into the engine and cause you a large expenditure.
So, I do not advocate eliminating PCV. I do advocate making sure your grommet is healthy or closing that hole and moving it somewhere else.
I wanted to eliminate oil contamination, intake debris, and the possibility of boost entering the engine. I saw this issue on my motor before removing the original setup. To help the engine breathe better/maintain ring seal, I added a breather to the front cover. Other than the smell while driving no problems. During high boost runs I no longer see any oil dripping from breathers or dipstick rising.
Even though "everybody does it," there's a better way!
Get a breather with a hose outlet and run them to the intake piping between the MAF (If you're still running one) and the turbo inlet. The intake will draw a vacuum on the whole crankcase even when you're wailing on it and burn off those vapors to boot so you won't smell like a gas station all the time.
What you have now is an unmetered air leak. You're drawing air in through that open breather that then goes through the PCV valve to the intake manifold. You also have the crank case at atmospheric pressure, when it could be a vacuum. Move that breather connection to after the MAF and create a sealed system again and all the air in the engine is metered. It'll probably idle better, too.
Funny that I’m saying this & something I didn’t expect. After 12 years, I noticed a little smoke coming from my breathers. It happens after a hard run and sometimes during a hot highway cruise. I can only see it if you open the hood.
I converted the front cover atmosphere venting to a PCV setup, works great and no more smoke. Compression and leakdown tests are all good, seems after 12 years there’s a bit of ring wear. If I had a PCV installed originally, I probably never would have noticed.
