Sal Lubrano
- Apr 26, 2002
Used Stock turbo w/adjustable wastegate rod- no play in and out, with very minor movement side to side. Worked great when it was removed. Would like $110 firm plus shipping
Another stock turbo but it is in pieces and the wheels gets caught on the turbine side. Make an offer
Used Console gauge pod- ( small crack over left pod and it has been cut in the center to hold a caspers thumbwheel chip push button) make an offer
Used stock lower control arms- make an offer
Used Ac compressor- (This was a four seasons rebuild which was removed after one summer and placed on a shelf. It has some rust on the exterior) Make an offer
Used 86-87 accessory bracket - (The lowest hole which is under the power steering pump is stripped and need to be repaired or a bolt and an nut can be used) Make an offer
