A small video of my buick
Wow! That thing is awesome! Bet you sneak up on a lot of people too, it is very quiet.
had trouble dl'ing it, seems it was a realllly slow dl
60kbs? But I will watch it soon.........then add a comment below
nice runs! that is my goal time between 10.5 and 10.0! very nicly done.
what is your set up if you dont mind me or anyone else knowing. Looks good in blue too.
XxDarkSidexX
Its a stock block with a eagle crank, eagle rods, je pistons (7.8to1 because its what I had), cam motion solid roller cam, dart pro 1 heads, jesel shaft mount rockers, victor jr e intake, #72 injectors, 4l80e trans, 8.5 rear with 373 gears. i still have a trans brake and cage to put in.
Should easily run in the 9's with a good launch off the trans-brake. How do you like the 4L80E trans? If I ever have the $$$ to put my Brick in the 9's I'd still like to have overdrive and it seems like a good alternative compared to building an all out billet 200-R4 or going with the Gear Vendors unit.
I love the 4l80 it is the only thing in the car I havent worked on. It is a great way to as far as a trans goes.
Thanks for the feedback, definitely sounds like a nice trans.
Nice!! I thought that track looked familiar;) !
