AC compressor won't cycle on
bnice
Well I don't know what happened:confused: to my AC compressor. It was Fine last year but now it won't cycle on. Any trouble shooting ideas as to what it might be.
Thank in advance for help
Put some gauges on a/c system make sure there's still freon in there or it won't kick on
Did you put the gauges on like 38turbo mentioned? There is a low pressure switch that will prevent the clutch from engaging if the system is low on charge.
If you do jump the switch and compressor runs don't let it run long...you will burn it up if there's no freon...as suggested put some gauges on it
