On a hotair motor with a 20* chip, start out with about 15 or 16# of boost and see what you've got...I'd bet you'll run just as fast there as you did when you tried to run more boost...
1. set FP to about 43#
2. set boost to about 16#
3. Make a pass
4. see what kind of KR you are getting...
5.TUNE FOR NO KNOCK!!!
6. oh yeah,TUNE FOR NO KNOCK!!!
7. and did I forget to mention,TUNE FOR NO KNOCK!!!
If you are getting any knock, then your tune is wrong...Retune(yep, you guessed it), FOR NO KNOCK!!! Check your O2 readings, with pump gas, don't go below 800...keep it in the 800-820 range...With race gas, you can go a bit lower, like 780 or so, but with pump gas, no lower than 800...If your O2's are lower than 800 and your only at 16# of boost, then up the FP about 2# and make another pass W/O changing anything else and see what happens...Your O2's should come up a little...If you are now at 800 or above(with NO KNOCK ), then increase your boost by 1# and make another pass...Don't change anything else...See what you get...Check O2s and KR...If you are below 800 and have some KR then increase the FP and don't change anything else...Make another pass...See what you get...If you now have O2s around 800 and no KR, then keep up with the pattern I've described...If you are still getting KR and O2s won't go up to between 800-820, then you've hit the max limit for pump gas and your 20* chip...You won't get any more out of it with straight pump gas...Stick a fork in it, your done...Once you've found out the max limit, then back all your settings to the point where you got no KR and have the max amount of boost at that FP setting...
Unless you put a higher octane fuel in there, you WILL NOT be able to run any more boost on a hotair car nowdays, because the fuel today is worse than it was 10 yrs ago...Hell, I think the stock chip was like 22*, but the gas was better back in the mid 80's...
Sorry for being long winded, but basically, that is how you tune these cars...
