Ac/Heating Units
kwcook
My heating and ac untis are all original and are starting to fail. The metal lines are starting to get bent or are getting cracks in them. If I were to take out all of the ac/Heating units what all would I have to do. Eventually when I felt like replacing the parts or found good used ones I would put it all back in, but for now I thought I should probably go ahead and take out the heating core stuff and salvage the good parts and replace the old.
Is there a trick to getting out the heating and Ac parts?
What about the metal lines that run to the condenser from behind the radiator, do I have to cap them off?
Do I have to run the AC belt, Delete Pulley?
Thanks.
Kyle- I would recommend you call Brian Weaver at GBODYPARTS. Do not use their website but he will have all the parts you need. I believe he is in the process of moving so be patient. Brad
