2 things come to mind, AC fuse under the dash and the high pressure switch located on the dryer. If you know your system is full pull the black plug off the high pressure switch, take a paper clip and jump the terminals in the plug. If the compressor comes on then your high pressure switch is bad, if it does not come on then it may be your fuse or something else.
