Accufab 90mm throttle body
S2V6RACER
Banned
Like it is in the picture. It is already been modified for the throttle linkage to be used on the passenger side, proffesionally welded by Billy at Gilsbach racecraft. It has the wiggens style clamp also. I am going to cut off the 4" pipe in the picture tight to the flange so you can weld on your own tube. You can also remove the flange from the throttle body and use a slip coupler if needed. I have over $500.00 into this thing. I need the TPS and IAC for new project so it that isn't included.
$300.00 shipped...
