Accufab Regulator & AN-6 Fitting
SuperCPA
I don't feel tardy.....
This adjustable regulator was gently used for roughly 50 passes down the dragstrip before determining that it was inadequate for my TA Performance setup. It comes with this trick AN-6 O-ring fitting for those of you interested in a braided hose return line setup. No welding or special tools necessary. This unit is also compatible with your factory fuel bypass line.
At $100.00 ground shipped UPS to anywhere in the lower 48 states you can save nicely on this pair of quality items. PayPal settlement is preferred and included.
Man that would be sweet if you knew the part number on that fitting! I sure could use one of those.
Yeah that's the right part, the trick is getting a 90* fitting/hose end after that to fit. I have all that sitting around here somewhere.
