I know this is a chassis question, but I already have rims and Wilwoods for my car so no sense posting in the wheels and chassis section. You guys would come closer to having actually measured your cars. I plotted out the measurements on my car on the computer last night and was wanting to compare to what others are trying. I have a stock suspension with locating brackets for the control arms so I can move the lower one around. The upper is fixed.
The front is QA1 coilovers so I can adjust front ride height easily.
A few specifics
3560 pounds race weight
48% weight on the rear wheels
3.7 rear gear, 28X10.5 slicks, turbo 400 trans
best 60 foot of 1.38, mostly low 1.4's
best 1/4 mile of 9.05@150
Currently car is set up with a IC of 53.5 long and 11.75 high
If I put it in stock locations it goes 74.7 and 8.42
I have available
47 and 12.75
53.5 and 11.7
57.5 and 11.0
68.4 and 9.5
73.8 and 8.5
I was under the impression that as you move the instant center center further forward you should also move it higher for better weight transfer. Looks like my brackets are forcing the opposite to happen. The car comes closer to "hopping" off the line when it picks the wheels up instead of lifting them and carrying them. Wheels come up about a foot off the ground, but it almost looks like the rear unload and drops them back down again to fast.
Something interesting to talk about. Any ideas? Are my measurements workable or do I need to see about doing major rework to get the numbers inline? Can ride height adjustments have that big of an affect? Maybe I should go the easier route and get some weight offf the front end!!
Greg Kring
Arlington, Texas
87 GN
A few specifics
I have available
47 and 12.75
53.5 and 11.7
57.5 and 11.0
68.4 and 9.5
73.8 and 8.5
Greg Kring
Arlington, Texas
87 GN
