Looking for a Sandbox to play in
turbobuick
Staff member
I am planning to bring my GN to the Nats this year and would like to find a class I can race on Saturday and I somehow do not entirely fit the rules for any of the race classes at BG.
Being a former TSO car from the mid 2000s the class my car fits the closest today is TSM. My car fits the rules entirely with the exception of having a standard coilover mount and not one that is canted. I am not sure how or why the rules allow a completely adjustable unequal length 4 link race suspension with aftermarket TQ boxes but not a standard coil over mount? The only difference I am aware of is having to run a slightly higher spring rate with a canted shock mount.
But I am not here to lobby for changes or create a debate only looking for an exception with maybe a weight or tire penalty? My car in Drag-n-drive trim weigh 3460 and I am bringing a set of 235 tires to test since I am planning to go limited 235 racing later this year. I would be willing to run on 235s which surely would level any perceived advantage my coil over mounting has?
I am looking to see if an exception can be made BEFORE I purchase a legal PTE 7275 turbo. While I can probably still hurt some feelings in TSO I do not want to race against 3000# S2 head methanol race cars with pin on frontends, this is NOT what my car was built for.
Specs
Drivetrain:
On-center Stage 1 TA heads, stock location turbo with full over the axle 4" exh. CAS V1 IC TH400 9"rearend.
Chassis;
25.3 Chassis cert, Unequal length stock style rear suspension with merilat rear Tq boxes, rod end UCA and LCA in stock mounting location with adj mounts. Viking coil overs stock location and mounting in the front with standard mount on the rear, Stock steering with manual S10 box and TRZ front UCA and LCA with billet spindles.
Body, completely stock fiberglass hood and bumpers only, all glass stock wheel tubs full floor and trunk pans, full interior with back seat stock dash and console and carpeting.
Your racecar does not currently meet the rules to compete in the TSM class. As you stated the rear shocks mounting is not legal per the rules.
Factory rear suspension mounting locations required with shocks in stock location. Coilover conversion allowed. (2019 change)
Thanks for responding Paul.
To be clear no exception can or will be made even with a weight handicap or running on a smaller 235 tire which is clearly at a dis-advantage?
I only ask since this rule is pretty much an aesthetic one and has no real bearing on the performance of the car and I am willing to handicap the car?
Like I said I built this car as a hot rod to enjoy driving and competing in streetcar classes which it has done successfully. I would think a "Modified Steet car" class would be a more appropriate place for it? If not that is fine it will save me $$ from buying a class legal turbo just to fit a once a year race car class.
Sick at the Green is at BG on the 29th which I would like to attend since I did welll at Rockingham. This is also a more appropriate venue for a proven street car like mine.
We currently have no rules concerning concessions or negotiations. I simply say if you would like to participate in the TSM class at the GS Nationals please refer to the rules and make your racecar legal.
Paul,
Thanks for reaching out and taking time to talk with me on the phone. I do have a better understanding of your position. I am going to look into moving the lower coil over mount to the back of the LCA bracket and your right it does look like it might not be that difficult.
If I do not make the TSM race this year I would like to request losing up rule on the coil over mount for next year? I will for sure participate. Like we discussed I really have a TSM car more so than a TSO car. This car has not been raced at BG since 2008 and it would be nice to have a class to return to.
Chris, we will welcome you in Buick True Street on Thursday.
Buick body and Buick engine street car class. Must be capable of a short drive. Pro Tree .100 light. Winning cars return to the lanes after they run (no pitting). Card draw for each round. 1/8 mile. That is the basics.
Thanks Kip, I am planning to be there Thursday for your Street car event and cruising Scottsdale that evening with the GN. I didn't want to tow the car down to just run on Thursday so I was looking for a class to race for Fri/Sat.
