S Spongebob Buick Abuser Joined Jun 22, 2003 Jul 16, 2005 #1 Is there a direct fit actuator for a PT 51? Or do I have to shim the stock one? Thanks...
J Jack Evers Member Joined May 24, 2001 Jul 16, 2005 #2 John Craig modified the compressor housing on my PT52 with studs so I can bolt it right up. Shims eliminated altogether. Attachments WGA.JPG 39.9 KB · Views: 102
J Joe Lubrant " The Right Stuff " Joined May 25, 2001 Jul 16, 2005 #3 Spongebob said: Is there a direct fit actuator for a PT 51? Or do I have to shim the stock one? Thanks... Click to expand... Limit & pte offer new direct fit actuators, with modified bracket. They are available in Standard spring or Heavy Duty spring version for higher boost usage. Joe
