Actuator for te44
If you have welding capabilities, you can take one of the compressor cover back plate clamps off and weld it to your stock actuator. However, you would need to determine the proper mounting position for the actuator, in relation to which backing plate clamp to use, before welding it up.
This picture shows a stock actuator with an H cover backing plate clamp welded to it. This actuator came from Precision as well.
Just to give you a visual example.
Other than this, if you don't want to mess with welding it up, Precision does sell actuators that already have the clamp welded in the correct spot.
Hope this helps a little.
Patrick
You need a special bracket for the 44, call limit,Telephone: (928) 453-7321
they can hook you up.
The stock will work
Drill a extra hole, slip it under the bracket on the 44 when I had one
I used washers under the other bolt to make it even
I have some in stock. New, HD units. Call me at the shop if youre interested.
