Adapter for Large Oil Filter.
HighMileage
Albany,NY
I'm looking thru one of the vendors sites,and notice a threaded piece that allows use of a larger diameter oil filter.
Wouldn't the o-ring mating surface have to be enlarged to accommodate a larger filter?
I've got a PF47 on there now. But I'd like to go fatter.
the oil filter it uses- for a Buick V8, i believe- has the same size o ring as the PF47/PF52, which is a Wix #51040
the bigger filter Wix part # is 51258
the o rings aren't the same, but they are close enough.
