adding ground to bottom of module good idea ?
tttype
would adding a ground wire to bottom of ignition module be a good idea ? Or does it get all its grounding through the wires in connector ?
Been a while since I messed with it - but doesn't it bolt to a thick steel bar that is bolted to the intake?
I am all for good grounds but it seems like it is well grounded as it.
I have a big ground strap from the manifold to the firewall.
Very common to do that. People powder coat parts & wonder why the grounds are flaky etc. File the area where the bolt goes & add a ground strap. Many threads about it curing flaky modules etc. Seach it on the other board or even read this link. Its not all about that but its mentioned a few times with good explanations.
More module problems?? code 42 - TurboBuicks.com
x2,very good idea.did mine that way,cleaned the back of brkt,where the 10mm bolt goes and added a ground. been that way for years
