I have an 87 TR that is stock but with an adj wastegate and a K&N cone air filter. Before I had the motor rebuild the VDO boost gauge read 14 lbs max. I just had the motor rebuild back to stock and now when you stab it, it goes to 22 lbs. The threaded rod on the wastgate doesn't look like it has been moved at all. What can cause this and how can I fix it? Thanks guys.
Mitchell
			Mitchell
