Adjustable roller rockers
Donald Smith
Who makes the best adjustable roller rockers?I am looking for a set i can just bolt on,adjust the preload and run. Don
I haven't seen any yet. You have to cut the mounting pedestals to clear them on all I have seen including the HS.
Just delivered a motor with HS rollers and like all the others, pedestals needed trimmed.
You can buy the T&D's all ready clearanced so you don't have to grind the pedastiles. Or atleast mine came that way for GN1's
Steve, think maybe the GN-1's came that way. At least the ones I have installed on GN-1's work w/o mods.
I "assumed" the post was in reference to stock heads.
If you are referring to stock heads then yes they will have to be notched. Pretty easy if the heads are off.(30 minutes). If they are on the car that is a totally different story. Metal shavings will go everywhere. I used an air die grinder. T&D Machine products can make you a set in any ratio that you want. I have a set and they are good quality product.
