adjustable wastegate
Would an RJC manual boost controller work?, I just bought one myself.
Adjust the boost with it, no need for adjustable wastegate.
I won't know myself until spring, but it makes sence.
If you have one I would use it.
The RJC boost controller goes inline ahead of the wastegate and bypasses the wastegate solenoid, if the RJC is set, for example, at 10psi, the boost builds to 10psi and goes through the RJC and waits at the wastegate until the boost increases the the factory set point, say 13psi, then the wastegate opens.
When the RJC is set at 20psi, the boost builds to 20psi goes through the RJC and because the wastegate is set lower than 20psi it opens immediately. The same happens at 25psi and 30psi.
I probably over explained. I have a tendency to do that, just ask my co-workers.
I hope this helps, George
