adjusting tv cable
jay dcpt
I want a little firmer shift going into second. Would I go a notch towards the front of the car or a notch towards the back of the car?
It needs to be as tight as you can go and still achieve WOT. Simply pull it back and flip the throttle open by hand. If it goes to WOT while not yanking the cable housing forward through the bracket then you got it. If you go to far back you will pull it back out anyway when you slam the go-go pedal to the floor.
