What is the approximate limit on horsepower with the 009 injectors?
What is about the best FP to run with these injectors?
I think mine is just a little over 45psi line off right now...
Would I be alright using a turbo that can support more horsepower than the injectors are limited to if I don't turn the boost up to the limits? In other words, does it really matter what turbo you use as long as you run it within the limits of your injectors?
I'm thinking of using a TA-53 thats good up to about 600hp, which I'm assuming is much more than 009s will handle. I have the stall to handle the turbo. Shouldn't I just be able to get the same power as before on lower boost levels?
Sorry for all the questions.... just curious I guess
