Originally posted by NEARING 274ci oncntr
S2 heads
9.5-10.0 to 1 comp
healthy solid roller but not huge.
3000lb car -99%race 1% street
proably going to a power glide.
P trim 63 turbos with .69 exh housings would get the job done and will spool fast enough to run a pro tree with no problems and you wouldnt have to run 50# of boost. I ran 8.20's with those at 3280#
Originally posted by EightSecV6 P trim 63 turbos with .69 exh housings would get the job done and will spool fast enough to run a pro tree with no problems and you wouldnt have to run 50# of boost. I ran 8.20's with those at 3280#
Like Billy said, Go with the 63s. 5.50 shouldn't be to hard if chassis is set up right. We put twin 63s on a back-halved GN that weighs between 3000 to 3075lbs and have gone 5.20s. It has a BIG BRUTE powerglide. Hopefully will go 5.teens to 5.0's after chassis shop. GOOD LUCK
Originally posted by BAGN Like Billy said, Go with the 63s. 5.50 shouldn't be to hard if chassis is set up right. We put twin 63s on a back-halved GN that weighs between 3000 to 3075lbs and have gone 5.20s. It has a BIG BRUTE powerglide. Hopefully will go 5.teens to 5.0's after chassis shop. GOOD LUCK
Excuse me for jumping in here!I just want people to know that I have a BIG BRUTE glide
that I'm considering to sell. It comes with a SBC bellhouseing but can be converted easily. E-mail me if any interest. Regards Lou
Originally posted by turbolou . . .I just want people to know that I have a BIG BRUTE glide
that I'm considering to sell. . . E-mail me if any interest. Regards Lou [/B]
