stack1
Senior Stacker
- Oct 7, 2006
I'm looking at getting a decent gaming computer, it comes with alot of software so I want to see what any experts out there think this setup is worth. Thanks for any input.
Case - Cooler Master 590 Centurion (Black) - 5 months
Motherboard - MSI P7N SLI Platinum (3-way SLI) - 1 month
CPU - Intel Q9550 Core 2 Quad OC'd @ 3.4GHz - 1 month
CPU Heatsink - Arctic Cooling Freezer Pro 7 - 1 month
Memory - 8 GB OCZ Gold XTC OCZ2G8002G (4 - 2Gig sticks) @800 for a 1:1 ratio - 4 months
Graphics Cards - 2 x BFG Tech nVIDIA GeForce GTX 260 Maxcore 55 in SLI for
graphics rendering - 1 month
Here are some specs for these two cards
-896 MB GDDR3 per card
-999 MHz Memory Clock
-448-bit Memory Bus Width
-590 MHz GPU Clock
-1296 MHz Shader Clock
-216 Core Processors per GPU
-DirectX v10 of course
- 1 x PNY nVIDIA GeForce XLR8 9800GT for physics processing - 4 months
Here are some specs for this card
-1024 MB GDDR3
-900 MHz Memory Clock
-256-bit Memory Bus Width
-600 MHz GPU Clock
-1500 MHz Shader Clock
-112 Core Processors
-DirectX v10
Power Supply - Xion Power Real 1000w (This is a modular PSU w/6 12v rails. It has 35 amps on each of the 2 PCI-E rails and 20 amps each on the other 4. More than enough to run a 3-way SLI setup, OC, and as many accessories as your case can hold. Plus it has blue LEDs inside) - 1 month
Hard Drive - 500 Gigabyte Western Digital Caviar SATA - 5 months
TV Tuner card (record video input, use computer as a DVR) - 5 months
Optical Drive- DVD Multi Recorder (DL, RW, CD, your basic stuff) - 5 months
Multi Card Reader in front
7 Case Fans - 2 120mm blue LED on top (exhaust), 1 120mm blue LED on back (exhaust), 2 120mm blue LED on side (intake), 1 120mm black on front (intake), 1 80mm blue LED on side behind CPU
Operating System - Windows Vista Ultimate SP1
-590 MHz GPU Clock
-1024 MB GDDR3
-600 MHz GPU Clock
-DirectX v10
