Oct 12, 2009 #1 F fastdon3 TGM PERFORMANCE Joined Jan 21, 2006 Messages 118 trying to find out whats a good fuel pressure to run with this pump running it now at 30 psi is that to low
Oct 12, 2009 #2 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,083 fastdon3 said: trying to find out whats a good fuel pressure to run with this pump running it now at 30 psi is that to low Click to expand... Same pressure you would run with any pump. 42-45psi line off.
Oct 12, 2009 #4 F fastdon3 TGM PERFORMANCE Joined Jan 21, 2006 Messages 118 might have a problem with pump i will try to adjust regulator
