M miggy STAGED UP Joined Feb 25, 2009 May 28, 2013 #1 Aeromotive A1000 low miles, braided steel lines -10 feed line with BG heat sink and system 1 fuel filter -6 return line has a small gash on it -10 pump to tank $450 plus ride
M miggy STAGED UP Joined Feb 25, 2009 Jun 6, 2013 #3 $300 plus ride Low miles on pump, pretty much you are buying fuel pump and the rest is free..
M miggy STAGED UP Joined Feb 25, 2009 Jun 7, 2013 #5 Ken Adams said: All of these itemsE-85 compatible? Click to expand... I am not sure if they are sir.
H highboostgn Well-Known Member Joined May 24, 2011 Jun 8, 2013 #6 miggy said: Aeromotive A1000 low miles, braided steel lines -10 feed line with BG heat sink and system 1 fuel filter -6 return line has a small gash on it -10 pump to tank $450 plus ride Click to expand... Pm sent with question
H highboostgn Well-Known Member Joined May 24, 2011 Jun 29, 2013 #9 I will buy everything minus the pump
H highboostgn Well-Known Member Joined May 24, 2011 Jun 29, 2013 #10 I will buy everything minus the pump
M miggy STAGED UP Joined Feb 25, 2009 Jun 30, 2013 #13 gnpoweredrail said: pump too? Click to expand... Yes Sir..
