BroadcastENG
 - Jan 11, 2022
Hello Braintrust,
I'm in the middle of cable prep for 2-way security and remote start system install and was looking for some guidance.
Q1: Is a relay required to trigger the trunk release circuit?
Q2: Where would the head lamp (yellow +) circuit connect to on the alarm?
Q3: Are all Pins that call out a 12V/12V Constant on the alarm to be source from the ignition switch harness? I prepped my cables this way.
A second set of eyes on the following pinout would be much appreciated:
Signal (Buick) to (Viper 5706V)
Constant 12V+ (Red) to 6-Pin CON: 1, & 10-Pin CON: 2,5,9
Starter (Yellow) (Cut) to 10-Pin CON: 6 (key side), 7 (car side)
Ignition (Pink) to 10-Pin CON: 10
Accessory (Orange) to 10-Pin CON: 8
Tach (White) to 24-Pin CON: 12
Neutral Safety Wire (Orange/Black) to 24-Pin CON: 13
Brake Switch (White) to 24-Pin CON: 20
Trunk Release (Black) to 24-Pin CON: 3
Parking Lights (Brown) to 6-Pin CON: 5
Head Lamp (Yellow +) to ?
Hood Pin (Gray) to 24-Pin CON: 9
Door Trigger (White -) to 24-Pin CON: 15
Door Lock (Light Blue) to 3-Pin CON: 3
Door Unlock (Black) to 3-Pin CON: 1
Horn Wire (Black -) to 24-Pin CON: 16
