Years ago when I got a Boost/Vacuum gauge I was also not sure if the Boost gauge was giving me the correct reading after years of service.
My home air compressor has two air regulator with gauges, one showing the actual air pressure in tank, and the other is a adjustable digital regulator that has a built in gauge.
I remove the hose line from the "Brass Tee" that feeds the Boost/Vacuum gauge, and secure it inline with the adjustable digital regulator hose.
Adjust the digital regulator down to "0" pressure, start the air compressor until it reaches normal rating air pressure. Then turn ignition in the on position, (DO NOT TURN ENGINE OVER).
Since my Boost/Vacuum gauges is digital I can see the Boost display "0"
I slowly open the digital regulator showing 15# and the Boost/Vacuum gauge was showing 17#
It's time for me to get another another Boost/Vacuum gauge
Hope this will help
