I did a search to see what timing and A/F combinations help spoolup, but of course it seems to be a 50/50 split as to what people are saying helps spoolup. So is there any definitive answer on this? More timing or less timing? richer or leaner??? I have a problem of my boost coming up QUICK to 5 psi, then stop. Then it builds up from there. My timing goes pretty much linearly from 32 degrees at idle up to 18 degrees in the upper right block (interpolated between the two areas). A/f goes from 13.9 at idle to 11.7 in the upper right block (interpolated again). Can someone please clear this up for me? More or less timing? More or less fuel? and what are the disadvantages to these fuel/timing settings?
Also, as a side note. It's been a while since I last played with the car (deployed for past 6 months). What is the conversion between Kpa and PSI??? What would be 0 psi in Kpa??
Thank You,
Derrick
Thank You,
Derrick
