if you have 3/4" between the frame and tire now, a 4.5 BS and 1/2" spacer will give you a "true" 4" BS and should net 1/4" of clearance on the frame side... From what I understand 3.75-4" of "true" BS is about "right" for a 15x8 with 275/60/15s on a G body... a 4.5" BS with a .5-.75" (12-20mm) spacer should get you there... If it were me, I would roll the fender lip and then measure how much clearance is between the tire and the frame, then measure how much the tire sticks out past the fender... Order rims with deeper backspacing and use the spacers needed to center the tire in the wheel well... I know several people have 275/60/15s without rolling th fender, but you gain a fair amount of clearance and it makes tire fitment easier... One more thing - are you sure your body mounts aren't sagging?
Personally I am not a fan of using air bags/shocks to get a tire to fit because of the negative effects it has- especially on your ride and launch
