Has anyone used these from H&R? My current air bags are shot and I am going to replace them, just wanted to know if it was worth it to install the spacers while I am replacing the bags.
I did use them on my car when i had airbags. i was able to run much less air in the bags. This in turn reduces the bounce you get when launching some cars. When the car bounces it unloads the suspension.
I wanted to revitalize this old thread. I installed the HRPartsnStuff airbag spacers about ten years ago, and they are still there. The problem I have with them is that over a short period of time, the spacers will slide rearward. They keep sliding rearward until they completely pinch-off the air lines going to my bags, which makes it impossible to fill the bags. To correct, I have to crawl under the car and push the spacers forward. Fortunately, the spacers are slippery enough that I can push them forward easily with my hand. However, I have to do this several times a year, and I don't drive my car very much.
Are people still running these? Do they show any traction improvement? At this point, I'm going to remove them. I may true to glue some rubber or something to them to keep them from sliding. Or, I may just leave them out.
Simple solution is to put an alignment dowel in these spacers & drill out a hole in the Polyurethane puck that it sits under to be able to lock it in place.
Similar to what HR do with their pucks.
I had to read this a couple of times before I understood it, but it does make a lot of sense. If I put 2 dowels in each spacer/puck pair, that would ensure that they always stay centered to each other.
