S
speedy1320
Guest
Something is going on under boost and I cannot figure it out!
I posted this a few weeks ago and I am looking for some more ideas from the turbo pros again.....
I replaced my water pump,timing chain and gears awhile ago. When I put the car back together and took it out for a spin.....i heard a noticeable HISS under boost.
I thought this was simply a loose IC hose....but NO CIGAR!
I've looked for vaacum leaks and all.....still no luck!
The funny thing is.....the car runs STRONG....it doesn't seem to be losing boost ?????
Could it be an exhaust leak? Why did this happen after installing the chain/gears ??
Thanx
Tom
87 WE-4
3" DP
ATR exhaust,3" cat.
ATR IC
Testa Chip
Walbro pump
Hot wire
green-top inj.
K&N 14"
160 Therm
Adj FP Reg, Adj wg
Thanx
Tom
87 WE-4
3" DP
ATR exhaust,3" cat.
ATR IC
Testa Chip
Walbro pump
Hot wire
green-top inj.
K&N 14"
160 Therm
Adj FP Reg, Adj wg
