b4black
- May 24, 2001
I once read about someone using a AIR/smog pump to pump air into the up-pipe just ahead of the turbo. The idea was that the extra oxygen would react with unburnt hyrdocarbons, expand and create more exhaust flow, thus faster spool-up. I guess this could make sense becuase there would be an increase in gases produced as hydrocarbons became CO2 and H20. But there a lot more to it than that and the only way to know for sure is to test it.
I think I have an easy way to do this and maybe I'll give a shot this weekend. Maybe you can try it to and see what happens. The Smog pump output can go three ways. (This is for the '83 TR, other years should be similar)
1. To the the air cleaner box (usually during deceleration)
2. To the converter (during closed loop/warm)
3. To the back of the intake and then the exhaust ports (during open loop/cold)
WARNING: this could kill the converter if you still have it.
If your converter is gutted or gone, then there is no need for AIR going to it. By either unhooking the switching valves or feeding them constant power (I'll get back to you on which it is) the converter air can always be sent to the intake/exhaust. This is pre-turbo, so it should have the same effect as plumbing it to the up-pipe, just a longer path. The extra volume of air may help assist the turbo (sort of a supercharger-turbocharger arrangement). It can't help at boost, but it might help with the lag (when backpressure is low).
Will it work?
Will it work?
