quickstrike
- Jun 4, 2002
First off sorry to keep posting so many times here, but I find this site very useful in my search for a faster timeslip. I hope someone has some questions I can help with in the future.
A previous post of mine was discussing my high VE numbers(120).
I just read something in the archives that may help. My ACT or IAT sensor is installed on the bottom side of the intake in the plenum area. If this was seeing hotter than normal temps because of heat rising all around the lower intake, and not reading the actual air temp inside, could this cause the ECU to try and lower the pulse width of the injectors, thereby causing me to have to add higher VE #s to compensate?
My temps are around 180 and up during a run, and I am only making half of my 14psi normal boost.
Maybe moving it to somewhere in the supercharger discharge tube would be more of an accurate representation of input air temp. Could this be causing my high VE#s?
Randy
Randy
