fontana said:Tip-in timing retard is known as Burst Knock Retard or BKR. You can see the parameters for its operation starting at $3384.
$3384 BRR active time (the active time in a stock chip is .1 sec)
$3385 TPS delta threshold to activate BKR (this is 9.8%)
$3386 BKR retard for active mode (this is set to 7 degrees)
$3387 if coolant less than 40 C skip BKR
$3388 if MPH > 50 skip BKR
The code to process this starts at $E5C3
HTH
Wayne
Your right, my bad.
