- May 28, 2001
Guys I need some suggestions
Had an airshifter put in the GN but I cant get a signal from the external tach wire to the shifter box.
There is a big external tach hooked up to this wire now. If we try to splice into it, the tach just dies ( No signal)
Is there any other spot I can tap into to get a tach signal to this box? I was thinking the white wire going to the coil pack but I was not sure if that will work.
Thanks for any help
Thanks for any help
