Akly control
1NASTYGN
I have the alky control dual nozzle with 3 bar map sensor. Has always worked great. I can't get it to test anymore. Tried wiring alky pump direct and it works. Any troubleshooting guides on the forum?
We have a forum for alcohol here.
make some time and call, i'll walk you through the tests.
M-F 9-6 est
Wanted to add for those you search
Well if your install included putting a bulb where it says POWER INJECTION.. and that bulb turns on when you press TEST.. then the controller is working. Maybe you got water into the pump cuasing its failure.
When you push "TEST" it applies 3.5-4.0 volts across the red/black pump wires with the GAIN knob set to position 8. 3.5v should make the pump move liquid, unless the pump is hurt. Typically from water getting into it.(example missing/damaged bumper filler and motor gets wet)
support
Julio,
Thanks for the troubleshooting support and answers. I purchased this system from you a couple of years ago and have never had problems. Again thanks.
