ALDL on T link
fast eddie
Senior Member
Hey Ken which color wire goes to what conector ?,took mine apart at the ALDL terminal three diferent wires.
ED ,Thanks in advance....... :)
It depends on when I made yours ... normally it is:
RED = serial data
BRN = Ground
ORG = ALDL
There was a period where the cables I used for making TurboLinks had different pin out/colors for the DIN connector, so make sure the ORANGE wire goes to the middle pin on the actual ALDL connector.
hey Ken the three wires i had hooked up to the t-link are orange,a black and a white wire with black stripe, the two wires on the top right of the aldl connector are what?,need some help here.
Ed
Hmmmm... not sure about colors there.
Do you have this all taken apart? If so, I'm not sure without looking at where they are attached on the board.
Are the wires still attached to the DB25? It depends on which module you have what the wiring looks like. We can solve it really quick if you order the upgrade! :) :) I'll just replace it!
