Alky Control Pump
SS/GN
Parts for these pumps are out there. Does anyone know the part # for the original pump. All I can find is 11-111-00ch-12v, on the body.
I figured out the parts from Shurflo years ago and have been rebuilding the pumps myself with zero issues and they put out 150 plus. As mentioned its 20 to 40 bucks in parts and very easy.
Part #'s by any chance?... Thanks Mike
I need the part # for the check valve assembly and the thin membrane gasket under the pressure switch. I have a pump with a small leak at the switch. Any help would be appreciated.
