Alky keeps fouling my plugs
blackbuick87
Senior Member
I think there is something wrong with my pump switch or the boost line its hooked to. I have it t'd after the "y" behind the turbo. I went for a test run and took it up to 15# and the alky did not turn on. So I gave the Hobbs switch 1/4 turn and then the stupid thing comes on at 6# and floods my motor. It wouldnt shut off right away either, staying on until my boost gauge dropped to almost zero. Is it the switch or where its hooked to? The switch should be all right since it is brand new. I am sick of changing plugs. please help
I think the preferred spot is inside the car right off your boost gauge and out of sight. Could have some weird stuff going on where you have yours.
I am going to try moving it today. I am running an .016 jet so I do not think that would be the problem.
