alky pump ?
kraus
I have one of razors kits in my gn,i have the alky knob all the way to 6.5 7 with the setup below is this common.Or do i need to adjust the pump speed or add fuel thru chip or something.I am going to a dyno shop next week to have it tuned in the rest of the way to make things closer then what i have them already.But am wondering if the knob position is normal i am running 25 lbs with 93 octane,knock 0-.3 using straight m-1 meth.or should i leave it till i go to the shop and see from there....
That is normal. If your seeing a little bit of knock, turn the knob up. Just make sure your airfuel is where it needs to be before you add alcohol.
Meaning if the motor is lean.. this will cuase knock. Example your air fuel is at 12.0 and your getting knock. Increase your injector DC and bring the air fuel down to 10.8-11.0.
Now if your air fuel is at 10.8-11.0 and you see knock.. then crank up the alky knob.
i am using erics new chip (tt6.0)that is run off my wideband i got the settings on 11.2 air fuel when going into boost mid and full.
25 psi and little knock, sounds like its tuned to me:eek:
Why bother to take it to somebody to get it tuned, it really sounds like all the tuning is DONE... no knock and lots of boost, what else are you going to ask for?
BW
Julio, i should have called about my last pm, im still busy with everything else but my buicks here lately... TTYL
BW
BW
+1
As long as the wideband and chip are doing what they're suppossed to be doing.. your done.
