Alky questions
turbofrank
1. What is mini overflow used for?
2. Read a post where someone says so often they drain and
clean intercooler and clean rust from the up-pipe from using
alky. Is this from using too much water in alky or cheap alky?
3. Most theads list pump at $60 i have not found one that cheap
yet. Who?
1. The mini overflow is used for the Radiator overflow because the stock overflow is used to hold the alcohol.
2. I'm not sure on this one because the alcohol is normally injected after the intercooler.
3. Northern tool has them for $49.99 but they are currently on backorder. I'm pretty sure this is the pump that everyone uses
http://www.northerntool.com/webapp/...4006970&PHOTOS=on&productId=9414&categoryId=0
HTH
David
87GN
Yes, that's the one. $50.........great price for a fine product. As far as rust in the up pipe...........I've never cleaned mine in four years because there was nothing to clean.
