John, point taken... but heres a different way to look at things. See one problem you havent taken into consideration is pump tracking time. Whereas you expect a pump to make rapid shifts in pressure settings which cannot happen. We are dealing with a motor not a fuel injector. This will always be a problem of sorts. If you use a small pump, then flow is diminished but it tracks pressure better. The larger the pump, the more it can put out..but its mass is an issue...Like a small block vs big block rev'ing
So trying to vary pressure in minute changes doesnt make too much a difference to your alky/air fuel ratio. See when you tell the pump to spray, its spraying against a pressurized track of air. So its having to fight this obstacle, then you have the mass of the pump which has to pressurize lines above and beyond to get the liquid misted into the motor. And this air thats now saturated with alky is getting sucked into the cylinders. A lot of stuff is happening really quick. Using a smaller pump will track pressure better, but then has reduced output capabilities. Like the difference between the Shurflo/flojet pump and an EFI pump. The EFI pump will accellerate faster to the pressure due to its size, but then has the flow/pressure problem. It cannot move the same volume. Let alone the media we spray we need reliable pumps.. I have a mini version of the Shurflo i'm currently performing tests on..just for pressure tracking purposes.
The engine can only take air thats saturated in alky up to a point. Beyond that alky bogs the motor down..its not like an infinite fuel that you can keep increasing pressure and have success. everything has a limit. The point where it reduces performance is then the time to figure out what to do next.
The idea of the progressive is to offer increased alky flow at higher demand levels, yet keep these pressure levels low to when the motor doesnt need it. So we dont have AFR going down to 8:1 when the alky hits the motor. Its really more of a drivability thing. Once you figure how much alky the motor needs at 26 PSI.. There is nothing in the world that is going to make more power.. problem has been getting to the 26 PSI and when the car is at 27 or 25 and your setup for 26.
I mean to really get things complicated, use the new NOS NOSzzles and inject alcohol along with an additional nozzle in the up-pipe for air saturation. Then control both systems of off vehicle load, IAT, knock, rpms, boost, etc.. make an ECU for the alky. have it track of off boost and make it a separate fuel system.
At the present time while sounds like a great idea, its one of those that a really complicated system $$$ wont move. Few want to spend 1000 bucks on a sophisticated controller that will require tons of time to dial in. And in the end the gain may be less than .1-.2 tenths at the track.
Alky saturates air. Trying to tame it like a fuel injector with exacting precision may not yield the results you expect. In a crude sense it works so well..it doesnt need this level of refinement, only on paper. Lots of stuff made for our cars with great hype..look at companies like Kenne Bell.. how much of that stuff really doesnt work but on paper
One of my first PAC kits went on a supercharged Camaro running a Paxton. Customer owns a wide band.. and gets flat 11.7:1 AFR from 3 to 8 PSI. When the car goes to 9 PSI..it adds a little more alky.when its at 7 it takes away. Yet on paper one would believe that RPM's would be better. FWIW, he previously had a system that switched on at 3 PSI and would drop the AFR's down to the lower 9's before changing over.
What can I say..trying to keep things as simple as possible. I'll keep the rpm experiment in mind
