I feel like making someone else rich today by throwing out an idea I had a few weeks ago. Someone may have already tried it, but I havent heard or read anything. When you need to pump more alky, most go with more nozzles and a bigger pump, etc. There is an inherent loss of alky line pressure from the boost that the alky pump has to overcome...if the pump is pushing 60psi, and you're running 20psi boost, you'll only be getting 40psi at the nozzle. Thats alot of wasted potential.
Why not run an additional hose off of a boost source to the alky tank, plugged right into the lid? Instead of having a little hole as a vent in the lid, you would actually have pressure pumping into the tank, which would completely overcome the pressure loss. You could throw on a check valve or a boost activated solenoid of course, to prevent vacuum siphoning and an IC filled with alky from cruising. I would run the hose to a boost source, before the alky nozzle, to prevent alky vapors from recirculating. Maybe even tap it in somewhere before the intercooler, in order to actually gain a pressure advantage. There is the possibility of pumping superheated air into the tank, but not if the IC is doing its job. besides, SMC originally designed their system with the alky tank sitting right next to the turbo. Talk about HOT! I dont think the air from this line would be so hot that it would cause issues. I expect to hear alot of "yeah that would never work", and then see a newly designed alky system on all the vendors websites, lol.
What do you guys think?
