Setting up system, anybody move their battery to the trunk and put the tank in it's place. If so, what kind of tank did you use, and where did you get it.
I mounted mine on the drivers side under where the charcoal canister mounts, I used a 1 Gallon Jaz fuel cell.
I cut a hole in the front of the liner (where the circular recessed area is under the canister) to make room and made a bracket to mount it...Looks real trick and works great (down and out of the way) I need to take pics sometime.
