nirto71455
- Jul 26, 2001
Hey Guys,
I'm running a D1SC blow through setup on my 71GS 455. I've ran alky (Methonal) on it since bringing it to life. I had a couple of questions in order to help finallize my tune.
Using my LM1, I've tuned my AFR with no alky so it's constanly at 11.7 to 12.0 through out the boost range (boost peaks at 12psi) and the car is intercooled via a large Bar Plate frount mount cooler.
My question is, at what point am I putting too much Meth in the mix? I'm currently running a M15 nossle drilled to .086 with the veins in the head filed in order to help flow more methonal. With that being said, my LM1 with the alky reads 10.8 to 11.3 under WOT with the alky kit spraying. Durning a 1/4 pass I'm using just about 3 pints of Meth per run.
Is spraying that much meth leaning out my mix? Would I be better off mixing some water in the meth and going with a smaller nossle until I can get some bog from the kit? I'm running a SMC progressive kit.
Thanks guys, hope to see you all in Phoniex.
--Rich
--Rich
