marleyskater420
still needs to learn
- Aug 14, 2004
Been installed for a while, and has worked perfectly in the past. Recently I had to change some wiring and changeout the ECU. The wiring for the Alky wasn't directly touched.
The turn-on LED light works, and so does the Power Injection bulb, as well as the light on the turn-on box. When I press the test button it makes a noise at the pump when the key is at ignition. Once I turn the car on, it does not, and it does not inject the alky when I press the test button. All the wiring seems in order, but once the car is on, the test button does not seem to activate the pump, even though it makes that "turn on" noise when button is depressed when key is only at ignition.
Usually the car sputters significantly, and the rpms will drop, but neither happens.
The LED's turn on, the test button will make the pump give that "turn on" beep when the test button is depressed if the key is at ignition, but once the car is turned on, the alky does not inject. The fuse looks fine and the wiring looks fine.
Any ideas?
Any ideas?
