Mountain GN
No, it doesn't have a V8.
- Apr 19, 2006
I have an AlkyControl system, and after a pump change last year, I noticed that it had stopped injecting progressively. Instead of the red LED coming on at about 5 or 6 PSI, I just get the green one around 10 PSI. I had e-mailed Razor about this, and he said to check the ground going to the pump. Well, I just sent the car to my buddies shop (same one who did the install) for a valve spring installation, and told him to check the grounds. He said all the wires were connected, and even ran a second ground to the pump, just to be sure.
Is there any other cause for this system to not inject progressively?
