Do they make a kit for our cars with these bolts. I order a DP and a billet vac block and they both came with it. Looks cool and wonder if i could them for other parts of the car.. Thanks
Originally posted by y26 Do they make a kit for our cars with these bolts. I order a DP and a billet vac block and they both came with it. Looks cool and wonder if i could them for other parts of the car.. Thanks
The load bearing surface on "hex socket head" screws (as they're called) can be very small. If you are replacing a wide "flange head" bolt with a small socket head, you could damage the material underneath (if it's soft) if it requires a lot of torque. Yeah, you can use a flat washer under the allen head screw, but now it's another piece to get lost.
Still, you're probably safe on non-critical fasteners.
I would never replace critical fasteners in the engine (eg, connecting rods, bearing caps, heads, etc) or suspension, except with original GM or maybe ARP...
