Hi Guys,
Just got done wiring the new system and while it's not done yet, the major wiring is done. I'm getting some pretty severe alternator whine and am not sure what to do. Here's the high points:
8g power wire ran on the passenger side directly from battery to trunk.
Signal/speaker wiring ran down driver's side. Using good wire as well. 16g speaker wire as well as good Scocshe RCA stuff.
Grounded in the truck to the trunk hinge bracketry - sanded to bare metal - star grounded.
All grounds are grounded to a common location. Used a Gold Plated distribution block for power and one from ground as well.
Gear:
Sony CDX-7850 head.
2 - RF Punch 100a2
1 - Older Targa 300w 2 channel amp for rear fill.
Audio Control 3XS Electronic x-over
JL dual 10" Power Wedge enclosure running off one of the Punch 100's.
Pioneer 2-way 6x9 for rear fill. (Cheap but new) ran off the Targa.
Infinity Kaapa 3.5's in the front - (Not yet installed or hooked up) - to be ran off the other Punch 100.
Is it possible that the front speaker wiring is causing this to happen due to not being hooked up yet. All factory speaker wiring was replaced with 16g stuff, so, none of the factory speaker wiring is connected. The front wiring is simply cut off and laying in the floorboard until UPS gets here with the Infinitys.
Every piece of this setup has been in my other previous cars with NO noise heard. The only new component as it stands right now is the Pioneers. (in 4x10 adapters, btw)
Any help guys? I think I was very meticulous about stuff, so I'm not sure where I went wrong. Any chance that the fuel pump hot wire kit is causing this?? Casper's kit by the way.
Thanks in advance!
Gear:
Sony CDX-7850 head.
2 - RF Punch 100a2
Thanks in advance!
