As you may or may not know the later 3800s, have an ignition system called the *Quick Start*. It uses 2 crank pulley interupter rings. One 3x, (like the stock GN one), and one 18x. Then by looking at which set of windows open in what order the module can figure out what coil to fire, with out having to wait for a cam synch signal. So it is in fact *Quick Starting*.
I found a dead 97 S/C crank pulley and robbed the rings off of it, and had a friend machine up a little adapter ring. Then cut the rings to enable bolting them on, and then by using long bolts, they also form *studs* for the crank pulley to bolt to.
And it definitely starts Quicker. Much Quicker.
I can say as fact the dwell control is different in the module, but the car sure idles nicer.
And this would be handy for someone using a batch fire system, since it eliminates the need for the cam sensor.
