alternator bracket
xrunner123
How many brackets are on the back of the alternator? There is one that is 1/2" or so thick black L shaped tube bracket. approx 4"x3". hole on one end and u-slot on the other.
Does this one go to the alternator and if so where? The other bracket I have hooked up to the top of the alternator, the back, and the header bolt- from what I hear this one should not be used?
The "L" shaped bracket goes from the back of the AC compressor to the lower front header bolt. It's a support for the accessory bracket. There is a long bolt that goes through the accessory bracket then through the AC compressor. The bracket goes under that bolt. Both brackets should be used.
